trailer ball/hitch ?
Piney
05-08-2005 17:53:47
My Dad"s got an 800 model tractor. Couple of questions--
== what "class" implement hitch does this have ? I"ve noticed that implements have a "class" type.
== Is there a way to afix a trailer hitch/ball to the rear of the tractor ? I"d like to pull a trailer when needed. THe tractor has a hitch point on the front brush guard, but its a bit troublesome to drive in reverse everywhere *grin*
Thanks
paul
05-09-2005 06:15:42
 Re: trailer ball/hitch ? in reply to Piney, 05-08-2005 17:53:47
Can we assume your dad has a Ford 800 series tractor?????
Or is it a Case 800 series?
Or is it some other brand????
Anyhow, most all tractors have the option to have a straight, or swinging, drawbar. This is a bar of metal attached to the underside of the tranny & has a hole in it to hitch implememts to. Some tractors were sold without, or the hitch & brackets were removed, but the mounting holes should be there, & you can get the parts from a dealer; tractor supply place; or a salvage (tractor junk) yard. You simpley bolt a ball onto this bar to have a ball hitch.
You can also buy or weld up your own reciever 3pt hitch if your tractor has a 3pt. I think an example is on a link in a previous reply.
As to the 'class' of implement hitch, you are pobably asking about the catagory of 3pt hitch????
They range from Cat 0, which is a non-standard garden tractor size, up to cat 4, which is for 300+ hp 4wd giant tractors. Most older farm tractors under 65 hp are catagory 1 3pt hitch, which is 26" between the arms. The bigger, heavier, & more hp an implement requires, the higher catagory hitch is required. Generally the space between pins increases, and the size of the pins increase.
Without knowing the brand of your tractor, I would want to guess you have a catagory 1 3pt hitch, but that is _only_ a guess. If your tractor is a bit bigger, it could be cat 2....
--->Paul
Piney
05-09-2005 13:55:31
 Re: trailer ball/hitch ? in reply to paul, 05-09-2005 06:15:42
Thanks for the info-- Sorry its a Ford 800 series. Its a CAT 1 3 point hitch.
==RON==
JMS/MN
05-08-2005 20:12:26
All 3 ph specs are at www.asae.org. Measure your components to determine class, according to specs.
TomH
05-08-2005 18:09:38
If the tractor is a Ford 800, i'd expect it to have a Category 1 hitch, but just measure what size pins it takes.
TomH
05-08-2005 18:03:50
If the tractor has a drawbar just buy a hitch ball that fits the trailer and the drawbar's hole. The tractor should be able to handle anything up to a couple of tons, but use your own judgement. If there's no drawbar you could get (or make) one of these:
