3 point hitch on belarus 250a
dickbanks
05-05-2005 19:52:20
Just bought a Belarus 250a. It has a Cat 2 hitch, but only 24 HP on the PTO. Can't find any tillers that fit Cat 2 that accomodate a HP that low. Can Cat I tillers be fit to Cat II 3-point hitch?
Thanks!
paul
05-06-2005 09:27:12
 Re: 3 point hitch on belarus 250a in reply to dickbanks, 05-05-2005 19:52:20
I should imagine that tractor of that size would be adaptable to cat 1 - sometimes the balls have both size holes in them, & there are different sway blocks/ sway bars set up for the 2 different sizes????
How long are the arms, typically cat 2 has longer arms (bigger arc of movement, lifts higher) and the arms are 32" apart. 24hp isn't even 1/2 way to a cat 2 implement power need, so can't see why they would do that.
But, yup, there are little sleeves at the farm supply store that sleeve the cat 1 pins up to the cat 2 hole size, and most cat 2 3pts will swing in the 8" narrower needed for cat 1 implements.
Once in a while a specialized hookup won't work quite right, and pto shafts tend to be longer if this is a 'true' cat 2 hitch.
--->Paul
Roy in UK
05-05-2005 23:02:08
Yeah you can buy little adaptor sleeves. I should imagine most dealers will have them in stock,( well they do here anyway)
