reese drum mowers and tedding
steveinmaine
05-04-2005 11:53:12
considering a reese drum mower with the tedder/spreader option..do those of you with this type of mower,go around and ted a second time or do you find the spreader/tedder does the job(assuming the down hay is not rained on)? looking at a 6"9" 2 drum manual(not hydraulic lift)..they told me my 38-42 hp tractors could handle it, but the web site says 45hp and up. anybody running one of these with a slighly lower hp tractor? any big advantage to the hydraulic lift other than transport?
Roy in UK
05-05-2005 23:31:20
 Re: reese drum mowers and tedding in reply to steveinmaine, 05-04-2005 11:53:12
third party image
I had a look at their website ( not familiar with that mower in England) What made me smile was the way they sing the praises of their belt driven mowers,the fact that they are a lot less complicated than those horrible nasty gear driven disc mowers, a lot less to go wrong etc etc.
You then scroll down to the bottom of the page and lo and behold they market gear driven disc mowers which are uncannily like the Lely! The power requirement for them is less too. I would love to see a belt driven drum mower in action, because if the drums are belt driven the knives on adjacent drums won't overlap will they?(Overlapping blades prevent striping ) Otherwise, if the belt became slack and slipped timing the blades would collide, or is it driven by a toothed belt. on a gear drive cutterbed they are 'timed' (as in the above illustration) so this can't happen.
Hay Dr
05-06-2005 05:54:54
 Re: reese drum mowers and tedding in reply to Roy in UK, 05-05-2005 23:31:20
Reese drum mowers are amazingly simple and do work well. They are extremely expensive. Roy you know the design of the CCM mowers is simple. The CCM drum mowers are usually a great fit for the smaller farmer that wants the cutting technology of a disc mower at an affordable price.
Roy in UK
05-06-2005 08:51:41
 Re: reese drum mowers and tedding in reply to Hay Dr, 05-06-2005 05:54:54
Yeah Hay Dr. designed by Paul Zweegers. I don't know if it is still true but all drum mowers and disc mowers used to carry a little tag somewhere on them "System Zweegers". 'New fangled' technology that goes back to 1969 I think! Your mowers look uncannily like the Fahr KM./PZ mowers that sold like hot cakes over here in the 1970's and 80's
Hay DR
05-06-2005 15:56:46
 Re: reese drum mowers and tedding in reply to Roy in UK, 05-06-2005 08:51:41
Our drum mowers are the PZ Zweegers 2nd generation design drum mower that sold in the late 1970's and 1980's. Most of our parts are interchangeable.
Roy in UK
05-06-2005 22:23:45
 Re: reese drum mowers and tedding in reply to Hay DR, 05-06-2005 15:56:46
Ah...Hence the feeling of "Deja vu!"
kyhayman
05-05-2005 07:38:14
Grass hay, I normally ted once (when first cut). Alfalfa, normally twice. Once when first cut, and once 2 days later with the dew on.
kyhayman
05-05-2005 07:36:13
Hay DR
05-04-2005 17:22:10
How much are they asking for this Reese mower?
JD70
05-05-2005 20:05:47
 Re: reese drum mowers and tedding in reply to Hay DR, 05-04-2005 17:22:10
What is the best value out there for rotary hay tedders? Price and quality. Another words, if you were going to buy a brand new tedder where would you put your money?
Thanks,
John
steveinmaine
05-04-2005 12:07:36
excuse the typo,that would be, of course, "slightly"
steveinmaine
05-07-2005 08:44:20
 Re: reese drum mowers and tedding in reply to steveinmaine, 05-04-2005 12:07:36
new 6'9" manual(not hydraulic lift) reese mower quoted at $4950...i have a jd 1020 (38hp) and a farmall 350 diesel which i believe is a hair over 40hp . the reese web site recomends 45 hp so not sure if i would have to downgrade to a 5'3" mower. anyone running one of these 6'9" with less than 45hp?
