6 foot rotary cutter blades
Dave from Texas
05-02-2005 11:50:27
I was just given a 6 foot Rotary Cutter (Brand Unknown). It has 5 foot blades. Do they make 6 foot blades or is the stump jumper bigger and all sizes use the same size blades?
RickB
05-02-2005 14:25:51
 Re: 6 foot rotary cutter blades in reply to Dave from Texas, 05-02-2005 11:50:27
Depends. For instance, Bush Hog Squealer blades are longer than Bush Hog Three Hundred series cutters of the same width. Model 307 (7') blades fit the Squealer SQ72 (6'). Best bet if you don't have ANY info on the cutter is to take the blades and maybe a blade bolt to a dealership to try to match up a blade that is sufficiently long to work for you.
