Case grain drill w/ single disc
Brian peppler
05-02-2005 07:30:05
I found a Case grain drill that has only the single disc to plant the seed. I will be planting in worked up ground that is sand will this work I have been told single disc grain drills would not plant the seed in the ground that well and throw the seed on top I will be using it to do food plots for small areas only. Thank you
gary tomaszewski
05-02-2005 20:57:40
 Re: Case grain drill w/ single disc in reply to Brian peppler, 05-02-2005 07:30:05
I have used a single disc Case (very old) for 20+ years. Does an excellent job, but would suggest a single gang roller to insure proper closing and good soil/seed contact.
Michael Soldan
05-02-2005 16:06:03
Brian, I agree with Allan and James, for the first hundred years of agricultural equipment drills were single disc and they did a dang good job. Neighbour had a single disc McCormick, more miles on it than a NY taxi cab and it worked great, finally replaced it with a newer double disc version. Mike in Exeter Ontario
Allan in NE
05-02-2005 07:43:23
Hi Brian,
Plant 'er. Whoever told you that drills need to have double openers needs to sit down and take a load off. :>)
Allan
James2
05-02-2005 10:02:08
 Re: Case grain drill w/ single disc in reply to Allan in NE, 05-02-2005 07:43:23
Good advice Allan. In "trashier" ground and if not driven too fast, I think the single disc does a better job.
Allan in NE
05-02-2005 10:05:11
 Re: Case grain drill w/ single disc in reply to James2, 05-02-2005 10:02:08
Way better job, especially if a guy is droppin' a little alfalfa in the process too. :>)
Allan
