Oliver Plow
James from PA
05-01-2005 19:28:53
I have an Oliver 5 bottom plow, cushion trip, with 14" bottoms. I think it is a model 565. I am going to use our International 986 with 18.4-38 tires to pull it. The problem I'm having it the tire is too wide to stay in the deadfurrow. Is there anything I can do other than getting a different plow to correct the problem. Thanks.
HA in Oh
05-02-2005 06:32:09
 Re: Oliver Plow in reply to James from PA, 05-01-2005 19:28:53
I use a 4/14 F145, that I bought cheap with my 4010 with 18/38's, it's tight but it works. Just hold tight to the land side.
Larry NE IL
05-01-2005 20:36:20
James,
I don't see what the problem is. Yoy are still covering the same amount of ground and the compaction from the rear 18.4 tire riding up is neglegible. Just steer straight and keep on plowing! Larry NE IL
ejr-IA.
05-01-2005 20:35:57
Don't worry about it just get your tire and hitch lined up right so your wheel runs close to the furrow slice.
