Sid... Thanks. Will check the alignment. The reason that no down pressure is a problem is that the mower is badly unbalanced to the bar side. The 3-pt mount can't be offset enough to get it balanced, so it tips badly to the bar side. Even the tilt adjustment of the lift (MF 35) can't compensate enough. This isn't a problem in mowing, but when I lift with the tractor lift (remember, mower lift isn't functional), at full lift, the bar droops badly. It get's the end off the ground, but not by a lot. The reason this is important for me - now don't laugh! - is that I only have a few acres, and it has underground sprinklers, and I have to mow around risers, so I have to lift at each riser. Yes, indeed, it is a pain, and you probably wonder why I bother. I enjoy raising hay, and don't need to make a living at it, so going to all this trouble for just a few acres (embarassed to tell you, only 3+ acres) is not at all cost effective or efficient. Nevertheless, I have a waiting line to buy my hay if my first customer doesn't want it (she'll take all I can give her), so I don't have to look for a market. Of course, this also means that it's tough to put much into equipment. That's why I struggle along with what I have and have to balance repair costs against replacement, just like real farmers. However, there comes a point when it is no longer fun, and repair costs too much to justify. Maybe it's time to bite the bullet and replace with soemthing better. Thanks again...Chuck
