I think you are following the natural course of evolution. I did and now that I"m retired, I have something to do that is outdoors, creative, natural, propagates life, and partially pays for it"self.....which my fishing never did. A tedder allows for even curing. I tried several things to "get the hay right", but having cows and a back pasture that has beautiful grass that horse folks love, I had 2 types of hay to bale. Cows get fed long stem, coarsy sudan sorghum and the horses light, fine stemmed, grasses. Cow feeding is best suited to the roll while the horse owners perfer squares. The haybine works fine on both. I don"t like mowing wet grass so I usually wait to mow till 10am ish. The haybine is 9", easy to connect and disconnect, very versatile, easy to operate, and makes as much windrow as I want. On the stemmy stuff I roll for cows, the conditioner crushes the stems so it cures more evenly. The grass, being fine stemmed goes thru the conditioner without event. The last (of 3) sickle mowers I had (currently have none...yeah) I couldn"t get the early season grass to cure cause it would lump up. Always had big clumps of grass here and there, especially in turns where the cutter reverses to make the square corner. Bought a tedder to follow the sickle (another trip) to scatter what I had cut. Worked ok after I modified it so it would do the job it was supposed to when manufactured. The haybine doesn"t make clumps so I don"t need the tedder and since it cuts both nicely, that"s my cutter and tedder combined. Neighbor had a D17 and put out 5x6 rolls of coastal bermuda for years. Based on that I would say it"s a good enough match. On hobby or not, I suggest you find a good local tax preparer that caters to the farming community. You"d be suprised what is written into the tax code that can offer a big advantage for you. Good luck, Mark
