JD 3 Bottom Plow
Jerry (AL)
04-29-2005 14:44:28
The plow I have looks just like the one posted by Steve in the help identify photos with the exception of the semi-round pieces on the top of the front of each plow. Mine doesn't have those pieces and I wonder what their purpose is. Everything else looks identical. I measured the plow today and mine is definitely a 3 X 16.
I did find on the inside of the adjusting handle that showed the numbers "A12906A". The furrow wheel has a stamping "D920A" on the wheel itself.
My problem is the arm for the tail wheel is broken and I need to either find one or make one. Can some one post a photo of the arm that shows the shape from the turn in the arm to the clamping bracket. All I have is the wheel and the arm up to the turn. The rest is missing.
Also, is this 3 X 16 a 125?
BushogPapa
04-29-2005 18:56:36
 Re: JD 3 Bottom Plow in reply to Jerry (AL), 04-29-2005 14:44:28
Those curved arms over the moldboards are called "Coverboards" and take the place of the old "Jointers" they curl the edge of the ground down for good coverage when turning sod..they should NEVER be allowed to get rusty..just like the moldboards....
Ron..
