Adjusting sicklebar hold down clips
Bkeepr
04-29-2005 05:11:48
My little David Bradley sicklebar needs the holddown clips adjusted so there's less play on the bar. I tried wacking them with a hammer to tighten them up, but some pretty good wacks didn't do anything. I don't want to bend them out of shape as I'm not sure I can get replacements--is there a secret on how to do this?
thanks!
Tom A
Joel Harman
04-30-2005 05:34:31
 Re: Adjusting sicklebar hold down clips in reply to Bkeepr, 04-29-2005 05:11:48
Agree with Leroy. Manual will describe procedure as he did.
Leroy
04-29-2005 06:48:13
Those durn keys to close together cause many mispellings
Lerou
04-29-2005 06:46:13
Place a suport under the bar at each hold down, without this the bar has enough bounce that all you are doing is bouncing the bar and not bending the hold downs and unless it is the cast holddown then they cannot be adjusted that way but from most any mower should work
txgrn
04-29-2005 06:22:49
May have to remove from the mower to whack correctly, and it will take trial and error time, but it works. Lay them down on a concrete floor to whack.
Mark
Tom in TN
04-29-2005 11:29:42
 Re: Adjusting sicklebar hold down clips in reply to txgrn, 04-29-2005 06:22:49
Bkeepr,
I agree with txgrn 100%. I have an old Ford 501 sickle bar mower and the only thing that I have found that works is to remove the clip, clamp it into a vise, tap it a little bit, and then put it back on and see how it looks. You might have to remove it and tap it again one direction or the other, but you'll get it just right by doing this.
Good luck,
Tom in TN
