JD 3 bottom plow
Jerry (AL)
04-28-2005 09:03:49
I have a plow with a broken tail wheel assebly bracket arm that holds the wheel to the third bottom. I've been told that it may be a 145. Is there any one out there with a picture of a 145?
This plow has trip bottoms and has two pieces of channel welded together than runs the entire lenth of the plow on top down the left side facing the front of the plow and a lever at the front to adjust the plow left to right. It's a three point hitch.
I'm also trying to find a scrapped out piece somewhere since JD doesn't have this part any more.
Can anybody help with this?
MH
04-28-2005 10:20:43
 Re: JD 3 bottom plow in reply to Jerry (AL), 04-28-2005 09:03:49
Look under the help identify photo gallery, there is a picture of an F125 there. Your description sounds like that one.
Jerry (AL)
04-28-2005 15:45:48
 Re: JD 3 bottom plow in reply to MH, 04-28-2005 10:20:43
Looks just like the one I have but I thought mine was a 16. May have to put a ruler on it.
MH
04-29-2005 05:01:23
 Re: JD 3 bottom plow in reply to Jerry (AL), 04-28-2005 15:45:48
Mine is a 314, but these plows may have been available with 16" bottoms under the same model #?? Someone else on this site can tell you that, I am not sure.
paul
04-29-2005 10:58:57
 Re: JD 3 bottom plow in reply to MH, 04-29-2005 05:01:23
The 145 semi-mount came as 16", 14" - and with a deep-digging frog version as well, so I would guess the 3pt plows would also use the same model for different widths.
--->Paul
MH
04-28-2005 10:20:29
