Bushhog ATH 900 finish mower
Steve Ga
04-26-2005 17:50:59
I am replacing a bearing on a spindle,ATH 900.The bar on bottom that holds the blade,is it screwed onto spindle?or pressed on.I have heated,soaked etc. no luck.anyone done this repair.I have the bearing housing in vice,snap ringt out of top.Should the spindle drive out the bottom?Thanks
joe in pa
04-27-2005 14:34:23
 Re: Bushhog ATH 900 finish mower in reply to Steve Ga, 04-26-2005 17:50:59
I had a bearing go out in mine after less then 10 hrs. use on a new unit. I took it back to the dealer since it was still under warranty. to make a long story short, they ended up pulling out all 3 shafts and sent them out to have some machineing done as the clearences were not right from the factory. havn't had a problem since.
