JD 7000 4row wide planter
B Park
04-24-2005 19:45:38
I could not get my planter to drop any seed, all chains are on and tight. There is a broken spring that applies pressure to the drive clutch and makes it engage. Could this cause the problem I have? Also, how does the shaft that runs through the middle of it come out to replace the spring? Thanks,
BP
Heat Houser
04-25-2005 19:02:07
 Re: JD 7000 4row wide planter in reply to B Park, 04-24-2005 19:45:38
If your jaw clutch spring is broken, no doubt it is not engaging. You have a bunch of cotter keys to take out, chains to remove, bearing set screws to loosen, the drive keys to remove (inside the jaw clutch) and then it is your choice, drive the shaft left or right.
After it clears the spring, replace it. I would look at the jaw surfaces to see if they look square with the world. If the don't, the clutch will "jump a cog" and you will miss a bit of corn on every row. To look at online parts book, go to Link and sign up.
