#52 JD plow
Schrade
04-24-2005 06:19:55
Just bought a #52 JD plow Iam tring to restore it but still use it some. Id like to totally disassemble it but can't get the furrow wheel off it needs shims and seals or what ever is on the inside cap. Tried just hammering with no luck. Wheel does not fit over the end of axle hub. Not much room to heat if I have to. any other ideas. This plow on steel.
Leroy
04-24-2005 06:31:17
 Re: #52 JD plow in reply to Schrade, 04-24-2005 06:19:55
Are you talking the furrow wheel that is on the right side of plow ahead of bottom and is 28" in diameter or the tail wheel (15"?) at rear of plow, either way you have to unbolt and take apart wheel to get to hidden pin and there are no seals in those wheels, just a gasket where you take the wheel apart
Schrade
04-24-2005 07:35:49
 Re: #52 JD plow in reply to Leroy, 04-24-2005 06:31:17
Iam talking the large furrow wheel. I got parts break down from JD dealer {exploded view} showing every thing. Ialready had the pin out just afraid to bust things.
