Need help finding a sickle mower part
RocketScience
04-22-2005 16:21:57
You guys were a big help in locating blade guards that would fit my circa 1930's Oliver horse drawn sickle mower a few months back. I am now in need of what I guess is called a blade "outer shoe"??(this is what the guys over at Sickle Service called it).Simply described, it's the device at the far end of the blade that helps guide hay into the blade (kind of a wedge-shaped 'thing'). I would also assume it functions as a 'skid'device. Sickle Service does not handle any version of this item. Anybody got one sittin' around or know where I could get one? I'll retrofit if I have to. Any help at all would be appreciated. Thanks in advance.
Randy-IA
04-24-2005 18:40:01
 Re: Need help finding a sickle mower part in reply to RocketScience, 04-22-2005 16:21:57
Hi Rocket , If you need both a operators and parts manual you can get copies at the Floyd County Museum in Iowa . They have inherited all of the White Farm and Oliver Manuals as far back as ? .( http://www.olivertractormanuals.org/index.html )You may email the Floyd County Museum, or call (641) 228-1099. Fax (641) 228-1157. Hours are Monday-Friday, 9:00 a.m. to 4:30 p.m. Central time, year round. Postal address is 500 Gilbert Street, Charles City, IA 50616. I just copied and pasted everthing you'd need to get in touch with them . Good luck with your sickle and take care ...Randy
RocketScience
04-24-2005 22:22:29
 Re: Need help finding a sickle mower part in reply to Randy-IA, 04-24-2005 18:40:01
The possibility of an operator or parts manual for this thing?!! Wow! Thanks for the jackpot info Randy!
Randy-IA
04-25-2005 04:29:04
 Re: Need help finding a sickle mower part in reply to RocketScience, 04-24-2005 22:22:29
I hope they have it for you . They are supposed to have a manual for just about everything that Oliver ever sold back to the turn of the century . Good Luck ....Randy
Leroy
04-24-2005 06:58:30
Are you talking about the end shoe that is a cast part that has the last leger plate in it or the sole for under the shoe that you adjust for cutting height or the grass devider board that fastens to the end shoe as most replies seem to be about, That end shoe I think would be the same as for later tractor mowers and should be avaible if not from AGCO then from parts yards
RocketScience
04-24-2005 07:55:31
 Re: Need help finding a sickle mower part in reply to Leroy, 04-24-2005 06:58:30
Leroy, Thanks for the reply.
At this point, the only thing I got out at the end of my blade is the last blade guard. So, to answer your question, I probably need both (ledger/sole) if that's the set-up of the typical configuration. Problem for me is, I live in an urban area so I can't even go look at a modern version to check it out. I have looked at various photos on the web, and from what I can tell, some look like a two-piece unit and some look like a all-in-one cast unit. As I said in an earlier post and as you also alluded to, they do not look like they have changed much over the years, I could probably retrofit a later (modern) version.
Leroy
04-24-2005 09:40:12
 Re: Need help finding a sickle mower part in reply to RocketScience, 04-24-2005 07:55:31
email me @ [email protected] and I can probably mail you a picture so you can see what you need, don't know how to post on here. Leroy
RocketScience
04-24-2005 22:27:33
 Re: Need help finding a sickle mower part in reply to Leroy, 04-24-2005 09:40:12
Thanks Leroy. Email is on the way
Sid
04-22-2005 19:54:01
I know that part can be found at a couple of farm and home stores cloe by but they are for newer old mowers. You might try this site.http://www.macknair.com/default.htm Don't know nothing about them just ran across it looking around.
RocketScience
04-23-2005 18:05:08
 Re: Need help finding a sickle mower part in reply to Sid, 04-22-2005 19:54:01
Thanks for the response Sid, I'll give them a whirl too.
paul
04-22-2005 17:17:09
On sickles I work with, there is an adjustable shoe that slides on the ground, and another piece that stands vertically with a bar (or 2 or 3) sticking out curved to the back to flop the cut hay away from the standing hay. Guess I would call that piece a windboard or so.
On something that old, both may have been a single cast iron piece, I donno? But typically 2 seperat pieces bolted onto the end of the sickle out there.
Several farm supply stores such as T S C and the online v a l u b i l t and others have a universal windboard which would be a starting point if you need to fabricate.
(oops, got edited for a 'bad' word, need to spell it out.....)
--->Paul
RocketScience
04-22-2005 18:56:12
 Re: Need help finding a sickle mower part in reply to paul, 04-22-2005 17:17:09
Thanks Paul, I"ll check these guys out and see what they got.
