Here's an alternate method
RickB
04-19-2005 17:28:36
Set the cutting height with the cutter's tailwheel adjustment. Operate the cutter with the deck nearly level using the 3 point lever in position control as suggested, perhaps running the front a touch lower than the rear. If the cutter has a flexible link or similar on the toplink mount, run the toplink long enough to allow the cutter tailwheel to follow ground contours and still provide sufficient lift. If the tractor's hitch won't hold the front of the cutter steady, you can buy chains to run from the tractor's toplink mount to the lower link attaching pins on the cutter to limit the hitch lowering point.
