oliver superior grain drill
GGS
04-19-2005 13:04:09
Just wondering if you guys out there can answer my question. I was wondering if any of you have a chart to tell me what lbs per acre the seed box should be set at for timothy hay. the #,s go from 2 to 16 and i know thats not lbs per acre. Any help would be appreciated.
thanks GGS
Tom-Pa
04-21-2005 17:50:15
 Re: oliver superior grain drill in reply to GGS, 04-19-2005 13:04:09
GGS,
Email me and I can send you photos of the grain seeding chart and the fertilizer chart.
Tom-Pa
I Bleed Green
04-19-2005 16:34:46
Thats quarts of seed sown per acre. 1 quart of grass seed weights 1-1/2 pounds. 1 quart of clover seed weighs 2 pounds.
GGS
04-19-2005 17:13:08
 Re: oliver superior grain drill in reply to I Bleed Green, 04-19-2005 16:34:46
Thanks for the info. How about when your sowing 2 crops such as timothy and trefoil and you want about 8 to 10 lbs to the acre. What would you set it at 5?? Our john deere drill says you add the number setting of both seeds together and set for that. That works out to 8 so i don't know if these old drills work the same way.
