JD 335 round baler
PJBROWN
04-19-2005 05:30:37
We have a JD 335 round baler that we have had for a number of years and it has been a real good machine. It has the high moisture kit on it.... we make about 1200-1500 bales a year with it. A few years a go I started noticing that it didn't make as "square" of bales as it did when it was newer. The bale are not so much uniform as they used to be. Last year I bought new belts for it and it help out for a while ,but it's back to making sloppy bales again. Does anyone have any idea what could cause this ?? There's no slop in the roles... everything seems tight. Could the new belts stretch..... Thanks
Tx Jim
04-19-2005 13:16:22
 Re: JD 335 round baler in reply to PJBROWN, 04-19-2005 05:30:37
PJ,I'm not familiar with 335 but if it has hyd.tension as I think it does the valve that applies tension or the tension cylinders may be leaking internally.Are you filling each side of the baler equally?Tx Jim
Walter Squires
04-19-2005 11:18:00
Did you change rakes about the time the bales changed?
