plow setup
Red Rookie
04-18-2005 19:11:33
I have a 2 bottom IH trailer plow with clutch lift. One of the coulters is about an inch left of the moldboard and the other is about 4 inches left. Where should the coulters be set left to right and how high should the bottom of the coulter be in relation to the plow point? Thanks
paul
04-18-2005 21:19:53
 Re: plow setup in reply to Red Rookie, 04-18-2005 19:11:33
Most of the time, coulter should be a 1/4 inch or so left of the plow leading point.
Coulters need to run as deep as possible but not drag the bearing in the dirt. Typically coulters are worn out, anything less than 16" doesn't do anything for me.....
--->Paul
