605 G round baler
bbrown
04-18-2005 16:46:54
Im looking to buy a vermeer 605 G round baler. How good are these balers? And are there any tips for using it? thanks
Joe(TX)
04-19-2005 09:42:28
 Re: 605 G round baler in reply to bbrown, 04-18-2005 16:46:54
These are good balers and make a tight bale with a good center if run properly. They work better with an even full width windrow. Don't try to start a bale too fast or it wil plug up. Hay that is too dry does not feed very well if at all. The F series had a better tensioning setup.
thurlow
04-19-2005 06:20:19
Have had a "F" model for many years baled umpteen bales with it; agree with R. John; don't really have any tips; make a windrow you can be proud of and go for it..... ...
R. John Johnson
04-18-2005 22:38:08
The baler is basically the same as the 605F. The G uses just springs for bale tension, while the F uses springs and a hydraulic cylinder. I think there might have been some other minor differences. Folks up here were not as happy with their G's as F's, Super F's or H's, but that might hve been unique to our area. Check the archives for info on using a 605F and it should apply to a G.
Hope this helps
John
