290 corn planter
shadow
04-16-2005 18:40:14
Just bought a John Deere 290 two row corn planter. Can someone point me to a good place to get information on this? What is the checking wire used for and how does this work? Thanks!
Shadow
Indydirtfarmer
04-17-2005 18:18:55
 Re: 290 corn planter in reply to shadow, 04-16-2005 18:40:14
I've got a manual for that planter. If you're interested, let me know. We need to take the "transaction" off-site, and by email.
([email protected])
Dieselrider
04-17-2005 06:47:47
you can check out e-bay because they are on there all the time. Plates too.
JMS/MN
04-16-2005 20:16:25
It's likely you can still get the operator manual from Deere. Check wire was used to trip the planter mechanism every 40 inches as you went down the field. Wire was anchored at each end of the field with a stake, and moved after each pass, to line up with the planter for the next pass. IF you kept the wire tight- you could cross-cultivate the field easily. Otherwise, following the rows cross-ways was difficult. there should be a lever to set for 2-3-4 seeds per trip of the planter. Hill drop was another option, but did not use the wire, could not cross-cultivate. Drilling was another option- single seeds being planted continuously. Manual should explain all settings and adjustments.
