Shaft driven repair?????????
Tx Jim
04-14-2005 10:37:53
Hay Dr,other than HP requirements are there any other advantages to shaft drive over gear drive?Does it do a better cutting job under same conditions?Are they easier and less expensive to repair under normal use?What is your selling price of a TM700?Thaanks,Tx Jim
Hay DR
04-14-2005 14:31:50
 Re: Shaft driven repair????????? in reply to Tx Jim, 04-14-2005 10:37:53
third party image
Each Vermeer cutter unit is sealed with its own fibrex grease lubrication (lasts 20 years) and these shaft drive mowers can be run vertical all day long with no damage. The entire cutterbar can be disassembled and reassembled in 2 hours or less. Less Down time and less repair expense for the shaft drive design is the greatest advantage of the these mowers over the oil-bath designed mowers. The both use the same blade technology so they will mow the same if set properly.
The Vicon has a clam-shell designed oil-bath cutterbar with gears. You would not want to run this design vertically because you would starve the gears and bearings for lubrication. So you say who would run a mower vertical. Farmers with rolling land can be mowing around the side of a hill and that is the same effect. If one gear fails or a bearing fails the entire oil-bath should be drained and changed. Vicon even has magnets inserted to remove the metal shavings from the oil-bath. Vicon even recommends to change the oil. How would like metal shavings in your gear and bearing lubrication? If you fix the cutterbar correct you will have a day's worth of labor to pay for. Simply replacing the pod on top of the cutterbar means all those broken pieces are still down in the oil-bath. Are the in the bearings as well? so you need to split the cutterbar and clean all the parts. The Vicon works but is older technology.
Tx Jim
04-15-2005 03:52:24
 Thanks Hay Dr. in reply to Hay DR, 04-14-2005 14:31:50
Hay Dr,thank you for explaining cutter bar.Local Vermeer dealer I called first of week who said he just got back from sales meeting couldn't answer my question and was going find out. I'll call and tell him I already know design.How much do you sell one for,no trade? Tx Jim
Tx Jim
04-15-2005 03:55:46
 Mnimum HP required? in reply to Tx Jim, 04-15-2005 03:52:24
NT
Hay Dr
04-15-2005 05:48:00
 Re: Mnimum HP required? in reply to Tx Jim, 04-15-2005 03:55:46
third party image
To tell you the truth we live in the mountains and the smallest pull-type mower is 9'2" and is just too wide for farmers to pull down our roads. We tend to sell disc mower caddies because they pull down the road easier. In Iowa even the county roads are wide and Vermeer does not understand an 8' pull-type is the largest that can be pulled down the roads along the Appalachian MTNs. Another reason for caddy is you can wear out a disc mower and purchase another one and mount it on the same cart. If you purchase the pull-type non-conditioned mower you will have to rebuild the mower and that will cost more than purchasing the same size 3-point mower. The old 3-point mower usually will be traded in and it will still have some residual value to be applied on the new 3-point mower and lower that out of pocket cost. Pyramid caddies are $2,000. The Vicon and Vermeer pull-type mowers work well and we are hearing good things about both of them. Our preference is the Vermeer disc mower because of the hex shaft drive. Shaft drive mowers have a 1/3 less moving parts and require less HP per cutting head. The Vermeer TM-700 (9�2�) has a market price of around $9,500. The TM800 (10�6�) is around $10,500. When customers start spending over $10,000 for a disc mower only they usually start to consider the Vermeer MC840 (10�6�) mower conditioner for $16,500. Likely I made the water more muddy but I hope I helped you.
