Dearborn 10-80 Disc Plow
George N.
04-14-2005 09:30:36
Recently I broke one of the shafts on my Dearborn plow. It seems Ford no longer makes parts for these plows. After pulling the housing apart, I discovered the shaft/hub was forged out of cast steel in 1 piece. My solution was to have the hub bored out the same diameter as the shaft, have a shaft machined out of cold roll steel and simply welding the new shaft to the cast steel hub front and back with E-7018. As information for others, the 24" blades can be purchased at Agri Supply for around $28.00 (WWW.AGRI-SUPPLY.COM). The blades are 1/4" thick with a center hole but the 5 mounting holes for the Dearborn hub are easily drilled.
Scott PA
04-14-2005 17:40:53
 Re: Dearborn 10-80 Disc Plow in reply to George N., 04-14-2005 09:30:36
Is the part you are looking for the shaft and hub that the disc goes on or another shaft?
George N.
04-15-2005 06:18:04
 Re: Dearborn 10-80 Disc Plow in reply to Scott PA, 04-14-2005 17:40:53
It was the shaft/hub the 24" disc blade mounts to but I solved the problem with the help of a local machine shop.
If you have any spare parts, I would be very interested in hearing about them.
George
