Single bottom Dearborn Plow
Tom in Idaho
04-12-2005 21:31:04
I have a single bottom Dearborn plow that has two pieces that I am not sure how they attach or what purpose they have. They are about three feet long and have sort of a notched end. How are they used? I would like to see a picture of one with these pieces attached if anyone has one. Is this a handy piece of equipment?
Scott PA
04-13-2005 18:18:11
 Re: Single bottom Dearborn Plow in reply to Tom in Idaho, 04-12-2005 21:31:04
There are 2 bracket that need to be fastened around the pto on the back of the tractor for one end of the rod and the other end goes through the hoop in the top front of the plow frame to trip the bottom when you raise the plow so it is ready for the next pass in the field.
Tom in Idaho
04-14-2005 07:25:33
 Re: Single bottom Dearborn Plow in reply to Scott PA, 04-13-2005 18:18:11
Is this bracket normally attached to the plow or is it a separate part that I need to look for. If so, what does it look like so I can start my search?
Scott PA
04-14-2005 17:44:49
 Re: Single bottom Dearborn Plow in reply to Tom in Idaho, 04-14-2005 07:25:33
It is not attached to the plow it just lays in a loop holder, the end at the tractor is fastened. Mr. Bradish in western PA makes the tractor brackets and the arms, his number is 724-937-5151.
Leroy
04-13-2005 04:52:49
Without seeing a picture it is very hard to make a guess bit I would guess if they are a round rod type and curved that they are cover rods to help cover tall trash
