comer fertilizer spreader?
hubby'shelper
04-12-2005 16:47:10
I hope one of you fellas can help me out. My darlin" hubby bought a fertilizer spreader at an auction and was told all parts were there but we can"t seem to put it back together. The only name I have found on it is COMER, down on the PTO connection. Is there a place to see an expanded view of one to know if we are missing parts? Or maybe one of you could help me out?
Michael Soldan
04-13-2005 05:26:04
 Re: comer fertilizer spreader? in reply to hubby'shelper, 04-12-2005 16:47:10
Hubby's helper, is this a three point hitch spreader? If you can post a picture or give us a description we may be able to help you...Mike in Exeter Ontario
hubby'shelper
04-13-2005 08:08:49
 Re: comer fertilizer spreader? in reply to Michael Soldan, 04-13-2005 05:26:04
Yes this is a 3 point hitch spreader. I will try to get a picture up. Thanks for your quick reply.
hubby'shelper
04-13-2005 08:08:10
paul
04-13-2005 08:41:57
 Re: comer fertilizer spreader? in reply to hubby'shelper, 04-13-2005 08:08:10
Is it a metal or fiberglass cone, there is a spinner below the cone & it spreads the fert/ seed out behind as you drive? Would help if you could explain what you have...
Many seem to come from Italy & there abouts & are very similar. Worksaver has a full manual & parts list on their web site, pdf document you can save or print out. Try the obvious web site or search...
--->Paul
hubby'shelper
04-13-2005 19:39:31
 Re: comer fertilizer spreader? in reply to paul, 04-13-2005 08:41:57
The cone is metal and that seems to be part of the problem the holes on the cone do not match up exactly with the hitch part. The cone has 2 openings at the bottom plus a center hole that a shaft fits through that locks into the spinner. There is an adjustable plate that also fits under the cone to adjust the feed. But we just can't seem to make it all fit back right. He may just have to chalk the $35 he paid for it up to a lesson learned.
Michael Soldan
04-14-2005 05:38:17
 Re: comer fertilizer spreader? in reply to hubby'shelper, 04-13-2005 19:39:31
Just a thought occured to me. When I bought my spreader and tried it for the first time it would only cast out to one side no matter how I adjusted it. I called the dealer and he said he would send someone out. It seems when they assembled it that they put one plate upside down so it wouldn't correspond to the center position hole...is there a possibility that you have all the pieces but one needs to be inverted to make the shut off line up? You have my curiosity arroused and I hope you can get it figured out...keep us posted...Mike in Exeter Ontario
hubby'shelper
04-14-2005 20:48:13
 Re: comer fertilizer spreader? in reply to Michael Soldan, 04-14-2005 05:38:17
The WORKSAVER site helped alot. Unfortunately hubby got the flu bug and we have come to a stand still for a day or so.I will try to look at it myself tomorrow. Sometimes a different eye can spot the problem. The info about the inverted plate is interesting though. As a matter of fact I think he thnks that is just an extra one. HMMM
hubby'shelper
04-14-2005 20:47:38
Michael Soldan
04-13-2005 14:38:56
Paul, I have a 3pt spreader and it was made in Italy, I can't recall what trade name is on it, I will have to look when i go out to the farm in the morning
hubby'shelper
04-18-2005 08:31:34
 Re: comer fertilizer spreader? in reply to Michael Soldan, 04-13-2005 14:38:56
Thanks to all who responded. The worksaver site helped alot. He finally got it all together and is working. Thanks again guys!
