what size disc?
chuck t
04-12-2005 10:09:17
I have a MF 202 (37hp). I want a disc for the 3 pt hitch. Looking at a 7 footer; is this too big for my tractor?
Ultradog MN
04-13-2005 12:36:20
 Re: what size disc? in reply to chuck t, 04-12-2005 10:09:17
Your tractor will pull a 7 footer just fine.
My weak little 22hp 2N Ford pulls a 7"6" tandem
okay. Makes it grunt a little to lift it.
I don"t have any front weights on it.
Jerry
James2
04-12-2005 10:28:48
Should work just fine if you can lift it. May need to add front weights. We used an 8 ft Ford disk on a 39 hp Ford 961. It was a bit light on the front although we had a wide front end installed. Probably would have been real marginal with the narrow front.
