JD Grain Drill Feed Cups
Christos
04-12-2005 09:25:59
Hi All, I have a question, do any of you think that the feed cups on an Model FB Drill can be replaced with ones from a 450 Box Drill? I was going to go buy one and try it...but I was curious to see if anyone had managed to replace the feedcups or know of a place to get some from.
TomTX
04-13-2005 03:12:29
 Re: JD Grain Drill Feed Cups in reply to Christos, 04-12-2005 09:25:59
I don't know about the 450; but what I would do is call JD dealer and have him quickly look up the part numbers on both implements and see if they are common parts.
Tim(nj)
04-13-2005 19:53:09
 Re: JD Grain Drill Feed Cups in reply to TomTX, 04-13-2005 03:12:29
They are not common between the two drills. Last I went to dealer for some (2003) new FB cups were available. They are under a substitute number from the original. Cups from an FB-B would be a close match if original style can no longer be found.
Christos
04-13-2005 21:13:40
 Re: JD Grain Drill Feed Cups in reply to Tim(nj), 04-13-2005 19:53:09
Do you have a part number? I never thought of trying an FB-B.
