489 roll replacement
Gary54
04-05-2005 12:49:36
Have a 489 haybine and the rolls are starting to lose the rubber- how big a project is it to replace the rolls? Can I assume two rolls will run $1,500 +/-?
Sam in MI
04-06-2005 17:21:16
 Re: 489 roll replacement in reply to Gary54, 04-05-2005 12:49:36
I changed them on a 499 several years ago and they were $1700 for the pair then as I remember. It really wasn't bad to do as the rolls stayed in the frame and we dropped the header off to get access to them. I don't recall if a 489 is like that or not. The bottom roll came off, then there was a slot to drop one end of the top one. I did have a helper to drop the old ones and get the new ones put in as they are pretty heavy.
CEB
04-05-2005 14:40:52
It is a fairly big job and it is really helpful to have an assistant when you tackle this job. Your estimate of $1500 for two new rolls is fairly close. The rolls have to be timed to each other to mesh properly. In our area, you can buy a fairly decent 489 for $2000-$2500 at an auction, sometimes even less. I'm not sure it is even worth doing unless the rest of the haybine is really in mint condition.
Gary54
04-06-2005 18:28:37
 Re: 489 roll replacement in reply to CEB, 04-05-2005 14:40:52
I'm in upstate NY and seems like good 489's are bringing $4,000+ If I could find a good used haybine for $2,000 to $2,500 I would go that route and sell this 489 off
Ken M
04-05-2005 18:12:31
I"m curious if this is the Gary who"s 489 I worked on and used last summer and his daughter owns the farm?
Gary54
04-06-2005 18:24:28
 Re: 489 roll replacement in reply to Ken M, 04-05-2005 18:12:31
afraid not- we have had the 489 for four yearsnow and up to now have just had to replace the lower roller driveshaft and the grearcase seal
