Building a equipment trailer.
Bill Treebrook
04-05-2005 11:00:14
I will be building a trailer to haul a 1942 ford tractor soon and need some advice.Where can I get plans for a trailer with two axels using 15 inch tires. Thanks for your help in advance. Bill.
farmerboybill
04-08-2005 19:59:39
 Re: Building a equipment trailer. in reply to Bill Treebrook, 04-05-2005 11:00:14
4K got me a brand new deckover bumper hitch trailer with twin 10k jacks and 2 7k axles. It has 5 foot ramps, a 3 ft beavertail, and a 19 ft wood deck. The structural channel iron crossmembers are on 16 inch centers on 2 - 8 inch I beams. Way more than what you need but this'll give you a price comparison. The local dealership has a used unit for 1200 bucks which has 2 3500 lb axles and a 16 ft deck. That's more like what yoiu want.
Unless you really need something special, I'd go the new or barely used route for a very little bit more money than the cost of raw materials. From what I've been told, homemade trailers never trail perfectly straight unless the builder is a professional, either.
Good luck either way you go...
big jt
04-07-2005 23:55:25
I agree with Glenn. However Northern Tool has plans like what I think you are looking for and a lot of the parts.
I will reinforce the idea of buying a trailer already made. If most of the materials are going to be purchased new forget about building your own unless you need some special features for your purpose. Buying a ready made unit gets you new brakes (YES YOU NEED THEM) good tie downs etc.
JM2CW
jt
Glenn F.
04-07-2005 08:15:40
If you value your time at all I think you can buy a new manufactured one for less than you can build one. That's my conclusion. Glenn F.
colciron
04-05-2005 16:12:31
As well as NorthernTool.com having a catalog with plans and trailer parts you can find plans on Ebay and may even find plans on a search for "flatbed trailer plans" When you tire it be sure to put trailer tires on that are built for trailers. Also do a search on trailer parts on the net. I haul 51 and 52 8Ns with loaders, individually on a drop axle, underslung, tilt trailer that does great and loads/unloads like a dream. Drives just as well.
thurlow
04-05-2005 11:50:51
One of those catalogs you get every month has lots of plans..... ....Northern Hydraulics, I think..... .....
