JD 125 plow
Samual
04-05-2005 09:53:06
How old is a 125 JD plow? This is a 3 point mount.
Is it older or newer than a 55 ABH, JD pull type plow...
ANy reason against using a 3 point plow?
Thanks~
Indydirtfarmer
04-05-2005 09:57:30
 Re: JD 125 plow in reply to Samual, 04-05-2005 09:53:06
I THINK they came out about the same time as the F145 semi-mounted, which was 1962. (55 was quite a bit BEFORE the F125) Not a reason in the world against a 3-point plow IF you have a tractor with 3-point.... Anything 3 bottom or less and I'd recommend 3-point....
