Heston pt 10
Rae
04-04-2005 16:12:23
The ball and socket on the cutter drive on my Heston pt 10 seems to be loose. Has anyone had experience replacing this set-up? How much aggravation should I expect?
Tim IN
04-06-2005 08:58:08
 Re: Heston pt 10 in reply to Rae, 04-04-2005 16:12:23
You can try shimming with washers, however I recommend a replacement head. It should have the ball completely surrounded and is a better design in my opinion.
Joe(TX)
04-05-2005 05:19:30
I assume you are refering to the one on the pitman. It needs to be kept with as little play as possible or it will break The ball portion will break if it gets loose. These parts are getting expensive. Like Vapet said. There is an adjustment on the end. If it wont turn in, add a shim between the adjuster and the disc inside.
vapet
04-04-2005 16:29:33
Do you have one that is adjustable? Has a large slot in socket end with cotter pin in it. If so try adjusting but not to tight. If non adjustable will need new knife head.
