Keeping plow share bolts tight
John51
04-03-2005 03:03:56
Well I finally plowed a little and then it stared to rain. 2 inches on top of 2 inches 5 days ago! Anyway, my IH 710 plow loses shares. Any tricks for keeping them tight? I crank the nuts as tight as I can get them but by the end of 5 acres there is always a share coming loose. I do hit a lot of rocks. Ideas? Thanks.
James2
04-03-2005 19:42:03
 Re: Keeping plow share bolts tight in reply to John51, 04-03-2005 03:03:56
I never had any come loose, but if I had a problem I would use bearing race red loctite. They will not come loose, although you will need to heat them up whcn you are ready for replacement.
TP from Central PA
04-03-2005 18:03:48
Which ones on the share are coming loose? We"ve always ran a right hand threaded plow bolt on the first hole(Closest bolt to the furrow wall) and then regular lefty"s on the other ones. A half inch impact will help too, I"ve done that a few times when I could get the plow high enough to get the impact under there. I had a heck of a time one year keeping them tight on our IH #60 trailer plow..... ..... .Got a long 1/2" drive breaker bar and reefed on them..... ...Didn"t have any trouble after that.
P.S, check your frogs too..... ....if they are worn out that doesn"t help either.
Dave Sherburne,NY
04-03-2005 17:09:16
When I was plowing with JD 7bottom Variable width,
about a thousand acres a week, I had to replace brazilian points quite often. They always come with
new bolts. I would use a breaker bar to tighten
as tight as possible, then take the old nuts from
the points I had removed, and double nut them.
The double nut kept the dirt out and kept the thread
from getting buggered up. When it came time for a change I never had to go get the torch and they
never loosened up.
thejdman01
04-03-2005 16:40:49
id tighten at least with a half inch impact. some blue loc tite has always worked for me. the red stuff is the next step though i am beting if you step up to the red you wont get the bolts back apart only way then would be torch or snap them. another way is to goober up the threads w/a hammer/punch wahtever again though your result would be snapping or torching bolts when time to replace
Hugh MacKay
04-03-2005 14:41:30
John: Do your plow share bolt have right or left hand thread?
John51
04-03-2005 14:52:00
 Re: Keeping plow share bolts tight in reply to Hugh MacKay, 04-03-2005 14:41:30
Hello Hugh, I was hoping you would respond. You probably have more moldboard experience than anyone on here. I'm using standard right hand thread bolts. Haven't seen left hand ones in years but they must be available. Do you think that would help?
Hugh MacKay
04-03-2005 17:02:49
 Re: Keeping plow share bolts tight in reply to John51, 04-03-2005 14:52:00
John: My plow was a model 510, 5x16. The Super Chief bottoms however would be same as yours. I had my plow about two years, came home from IH dealer one day with a new set of shares and bolts. As I changed them, I noticed this right hand thread was different, dealer had always given me left hand thread bolt in the past.
I started plowing, and within an hour I had a share hanging, went back to investigate. All five were loose. Tightened them, and since I had lost bolts on the one hanging, I had to replace those with the old left hand thread bolts. An hour later I stopped to check again, share with the left thread was tight, but the rest were all loose again. I went to phone, called the IH parts man, told him my problem. He did a bit of reading and got back to me in 5 min. This dealer had sold his first roll over plow, IH had added right hand thread bolts to his parts inventory. I had gotten there before parts man had got to his new reading material, thus bolts were given to me without checking. The new reading material I refered to was, " Right turning Super Chief moldboards must have left hand thread bolts and Left turning moldboards must have right hand thread bolts.
It works, I can tell you the bolts need to be little more than finger tight. I have never owned a roll over plow. The 510 probably plowed 5,000 acres during time I had it and never lost a share with left hand thread bolts in right turning moldboards.
the tractor vet
04-03-2005 16:05:37
Also how good are your frogs if they are wore way down then no bolt will hold here in the buckee we rase 150 bpa corn and 650 bpa rocks and i have broke my share of shears and even knocked a whole bottom off sheared off three 5/8 bolts but wore frogs will get ya every time. . When i put mine on i hit the plow bolts with a hammer while tightening them and beleive me they are tite and a torch is required to remove , sometimes i end up with the left hand thread and sometimes the righthand thread . Try beating on them while tightening them and see if that helps.
