JD 55 ABH Plow
Roy Hobbs
04-02-2005 12:47:08
Can anyone tell me if plow bottom parts(12") are still available for this plow? I am restoring one and want it to be perfect.
Leroy
04-03-2005 06:29:47
 Re: JD 55 ABH Plow in reply to Roy Hobbs, 04-02-2005 12:47:08
Depends on what bottom is on it, the bottoms on it are the exact same as for a 14" plow except for a shorter share, if you cannot find the corect bottom parts get 3 bottons off a 14" semi-mount and put them on and only the puriest will know the difference, they will bolt right on and would have been a replacement from JD back when throwaway shares first came out
Roy Hobbs
04-03-2005 10:58:51
 Re: JD 55 ABH Plow in reply to Leroy, 04-03-2005 06:29:47
Thanks for the info,Leroy.Sounds like A good option.
