7000 JD planter
jra
03-29-2005 21:06:26
I have a 7000 JD planter and have to replace the seed tubes every other year, due to them rubing the seed opener disks, and wearing one side of the tubes out at the bottom. Is there some way to keep them centered so they don"t rub, or is there a different type of tube that don"t do this?
JMS/MN
03-30-2005 07:24:18
 Re: 7000 JD planter in reply to jra, 03-29-2005 21:06:26
I would check for worn bearings on the openers, misalignment of the studs the openers mount to, or some problem where the seed tube is hooked on near the bottom, and pinned at the top. There should be clearance between those parts.
billyiron
03-30-2005 07:23:02
we have a JD 1770 planter it has a frog in the bottom of the tru Vs with a U piece welded on it to stop this,I think they cost about six bucks from Deere ;;;;;billy
