One bottom plow
Jackson
03-24-2005 18:46:50
I am looking to plow some fallow ground with old Christmas tree stumps in it. I tried a two bottom which pulled the stumps well, they just kept hanging up between the bottoms. What is the biggest one bottom plow that is reasonable to find, or am I thinking of the wrong way to break up this sod ground?
Thanks for your time,
Bill
Leroy
03-27-2005 05:50:11
 Re: One bottom plow in reply to Jackson, 03-24-2005 18:46:50
a single bottom 16" would be the larges size avaible and it would eliminate the hanging up between bottoms, if you didn't have a problem with the shares taking out the stumps, only with being to large to go thru the frame then a single bottom should work OK
RN
03-24-2005 22:09:49
Try to find a 2 or 3 blade disk plow- it was designed for sod busting in rocky/stumpy fields. Ford board has some postings comparing 1 bottom 16inch to 2-12 or 2-14 plows, also middlebuster plows for groundbreaking. Shep in Florida had some postings about using Oliver 550 with disk plow in cutover pine ground. RN
