GROUND!
John51
03-24-2005 09:42:02
Make sure you have a good ground. Not through the hitch but a seperate ground wire to the frame. It has been my experience that 90% or more of trailer wiring problems are related to a poor ground. And be sure to use a ground wire that is heavy enough for the job.
thurlow
03-24-2005 11:28:37
 Re: GROUND! in reply to John51, 03-24-2005 09:42:02
RIGHT!!!! I always assume any trailer wiring problems are ground-related until proven otherwise. I always ground everything all the way back through the plug.....there should be a pin for this....
Dave H (MI)
03-24-2005 13:30:19
 Probably mice! in reply to thurlow, 03-24-2005 11:28:37
If the wires run thru any enclosed areas, I would suspect mouse damage to the wires whenever there is erratic operation.
mike brown
03-26-2005 05:23:09
 Re: Probably mice! in reply to Dave H (MI), 03-24-2005 13:30:19
The best way to buy yourself light trouble is to ground through the trailer frame. Rewire that thing and ground all the lights through the wire harness to the plug and solder all the connections then use liquid electric tape and heat shrink tube over the joints. Led lights will be more trouble free than incondescent bulbs also. I maintain trailers at work and it drove me nuts to hook up to make a trip and have to frig around with the lights for and hour. After I rewired them all this way its hook up and go if you keep the plug clean.
