JMS/MN
03-21-2005 11:10:32
Re: wagon running gear question in reply to screaminghollow, 03-19-2005 22:38:12
If you pulled the right side of the rear axle forward it would only make it worse. Like others said- the reach is probably bent. Here, we call it a reach- the pipe that connects the front and rear wishbones of a factory running gear. Sight along the length of it. They are commonly bent by getting the wagon stuck in mud and powering them out with a couple of tractors hooked to it. Easy to straighten- you need one tractor, two anchors, and three log chains. The anchors can be trees, buildings, cars, tractors, MIL, etc. Two anchors on the convex side, one tractor and chain on the concave side, and pull ahead slowly until the reach is straight. The swaying in transport is because of slop in the front steering linkage- slop in bolt holes, worn bushings (if they exist), tie rod ends, spindle bushings, bolt or support at the rear of the tongue, where it attaches to the running gear. Very typical for farm trailers- they were not intended for highway speeds, although more recent models from major builders often trailed well up to 30-40 mph.
