How to plow fallow/never tilled land?
Dean Pecota
03-18-2005 10:45:27
Hi,
I have 5 acres I would like to hobby farm. The land was cleared of trees, stumps, graded, and planted with horse mix grass by the previous owner. The land may have been farmed in the past since there is a rock wall near by. The geographic area is littered with small rocks. The majority of stones are no bigger than a basketball. I would like to try and till the land. I have an old MF tractor that is 30hp and has no hydraulic remotes.
What is a good choice of plow?
I have seen pull type and 3pt type. I have also seen some labeled trip plows that kick out of the ground when they hit something solid. Intuitively I do not think that imparting the force of an impact into the 3pt would be good for the tractor. Would a pull type plow be less punishing to the tractor? I am willing to switch plow type at a later time when/if I get the fields clean. There are large established farms nearby which gives me confidence I can clean up the fields.
Thanks,
Dean
Dave in Mo
03-21-2005 09:45:48
 Re: How to plow fallow/never tilled land? in reply to Dean Pecota, 03-18-2005 10:45:27
If that was my ground, I'd subsoil it first. you can pick up a new one for your 3 point hitch for about 120 bucks and it'll have a 1/2 dia shear bolt to protect it. Do a crosshatch pattern and you'll get some quality seat time on the tractor. My 2 cents worth!
Leland
03-19-2005 14:59:05
I would hire someone with a ripper to come in and tear it up 1st ,this way he puts all the wear and tear on his equip and you don't tear your's up. You will be money ahead in the long run.
Hugh MacKay
03-18-2005 23:27:50
Dean: I'm with James, first off plowing in stoney or rocky ground is a 3 - 3.5 mph job, yes maybe even slower if conditions warrent. You will damage the plow long before the tractor. Go with either a one or two bottom plow with trip beams and yes 3 point hitch for that little tractor.
Personally if I were starting out in what you describe, I would go with single bottom 16" or 18". These plows handle trash very well even if not high clearence models. Rocks the size of basketballs suggest to me your going to find roots as well. Two bottom plow will work, your just going to find yourself back there more often cleaning it out. Remember also your hand on throttle and your gear selection will do far more to protect impact on tractor than any break away device.
From your description you want to clean this up rather than bury. If I were you I would also find a 3 point S tine cultivator about 5' to 7' wide. These require about 1.25 to 1.5 hp per tooth or shank. These will do and excellent job of putting rocks and other trash on surface. If you wish a photo of these send me an e mail. My e mail is exposed, just click on my name.
James2
03-18-2005 13:34:25
No contest, get a 3-point plow, just don't plow in road gear. If there are a lot of rocks, limit speed to 3-3.5 mph and have a trip bottom plow if possible. I would prefer spring reset to shear pin, but for 5 acres it really is not a major issue. These small tractors are designed to work best with 3-point attachments with the resultant weight transfer capabilities
JMS/MN
03-18-2005 12:19:39
If your tractor has a 3ph you could use a two bottom plow with trip beams to protect your tractor from hitting rocks. With a pull-type plow, and your tractor has no hydraulic remote, you could use an older ground lift plow with the spring release on the hitch. Later pull-types also had trip beams, but they might require a hydraulic lift cylinder. You may be able to easily add a hydraulic remote to your tractor.
