Push Rod for Ford 501 Mower
sean monaghen
03-18-2005 06:09:43
If some one has a good picture and some measurements for the pushrod that connects to the bell crank (left side) and then connects to the "clamp" on the left three point arm I would be very thankful. I am going to try to make a replacement since FNH wants almost $400 for the part.
Jerry D in NC
03-21-2005 06:08:32
 Re: Push Rod for Ford 501 Mower in reply to sean monaghen, 03-18-2005 06:09:43
Here are some pictures from my website that will get you started. I have opened my email so you can email if necessary for more detailed or larger photos
third party image
third party image
third party image
third party image
Oggie
03-20-2005 06:12:11
Just get a tie rod from an old car or pickup from a salvage . It's 20 1/4" center to center of the joints.
Jerry D in NC
03-18-2005 10:54:42
Something is wrong with that price. You can get them at most farm supply stores for around $15. Check with another FNH dealer. Use that one for a pattern. I usually make 6-10 at a time as setup for the saw is the most time consuming part of it. Remember the pittman rod is the fuse in the system that keeps the mower from self destructing....
paul
03-18-2005 12:02:52
 Re: Push Rod for Ford 501 Mower in reply to Jerry D in NC, 03-18-2005 10:54:42
I think he's looking for that triangulating lift arm with the 2 ball joints that is used to lift the bar - clamps to the 3pt arm. Not the wooden push rod?
I wonder if some sort of control rod from a junk yard would work out?
--->Paul
Jerry D in NC
03-18-2005 17:04:45
 Re: Push Rod for Ford 501 Mower in reply to paul, 03-18-2005 12:02:52
UT-OH Read too fast. Mine is not under snow, I will try to get a picture tomorrow
paul
03-18-2005 10:34:53
You shoulda asked yesterday - mine is under 12" of snow today..... .
Wow, $400. Here the whole mowers sell for $150-350 in good shape.
--->Paul
sean monaghen
03-18-2005 13:16:27
 Re: Push Rod for Ford 501 Mower in reply to paul, 03-18-2005 10:34:53
when your snow melts could you look and give some measurements?
yes I am looking for the part that has a ball joint at each end and clamps to the 3-point arm and the bell crank. Not the pitman rod (wood), I got one of those at TSC for $8.00
sean monaghen
03-18-2005 13:13:34
