Flail mower
jra
03-17-2005 22:14:56
What"s the difference in a fail mower and a bush hog type mower??
BushogPapa
03-20-2005 11:43:02
 Re: Flail mower in reply to jra, 03-17-2005 22:14:56
Flail mowers require a lot more power to run in heavy stuff..but I like the job they do in pastures, and you don't have to "lap over" to do a good job... I would estimate that it takes at least 40 HP for a 6' flail, while you can get by with 30HP with a 6' Bush Hog... In light stuff you won't need as much power..
Ron..
Don-WI
03-17-2005 22:21:31
A bush hog type mower is like your lawn mower, has 1 or 2 blades swinging around, parallel to the ground. A Flail mower is a whole crap load of knives mounted to a drum of sorts, rotating perpendicular to the ground. Flail mowers are better for cutting long stuff, but they also work pretty good for finish mowing as well.
I'm sure someone has a picture of each one they can post.
Donovan from Wisconsin
Hay Dr
03-18-2005 08:16:13
 Re: Flail mower in reply to Don-WI, 03-17-2005 22:21:31
third party image
Don,
You have described the flail mower properly. I just wanted to make it clear that a drum mower is not the same as a flail mower. Drum mowers cut the same as disc mowers.
