I Need Help with a New Holland 260 Right Hand Rake
Jerry D in NC
03-15-2005 19:29:00
We have been told that the same teeth that work on all of the other NH rolabars work on this model as well..... They don't. The clip is wron g and if you mount them on the back of the bar it catches the strippers. Does anyone have one of these rakes and can tell me what teeth will fit????
Jimmy King
03-16-2005 05:00:37
 Re: I Need Help with a New Holland 260 Right Hand in reply to Jerry D in NC, 03-15-2005 19:29:00
The teeth on a 260 are different than a 258 or 256. If you hold them up side by side the end of the tooth bends the opposite dirrection. They do have a different part #.
Jimmy King
03-16-2005 04:58:22
RickB
03-16-2005 03:44:18
You are right, they don't. The only NH p/n listed for the 260 is the 850614 rubber tooth. Check to see if Deere, New Idea, or CaseIH has a listing for a steel RH rake tooth. That is about your only option.
Tim(nj)
03-15-2005 20:54:06
Are these steel coil or rubber mounted?
Jerry D in NC
03-16-2005 02:53:27
 Re: I Need Help with a New Holland 260 Right Hand in reply to Tim(nj), 03-15-2005 20:54:06
We are trying to use the metal teeth with the clip that holds it on. NH only has one part and lists it as working for the 260 as well as all of the others. We are looking to use the metal teeth from a cost aspect....
