There are two things I believe drive baler price. 1st location. If you�re out in the middle of farm country and your neighbors talk in sections (not acres) you will probably pick up a good small square for next to nothing. But take a junk baler to an area outside of populated rural American where 10 acres qualify for subsidies, and it'll fetch quite a bit more. I live in northern Ohio. Literally on the line between over populated rural and some really nice farming communities. If I go north I can expect double the price than if I go south. 2nd Name. Put JD or NH in front of the model number and you can expect to tripple/quad-tripple the price. I have seen junk NH baler with grass growing in bale chamber, missing knotter parts baler fetch $800. JD14 (it was in good shape) do $2000. Take a decent case, ford, IH, or AC - $2-400 tops. Currently run a ford that will bale 200 and hour and not miss a tie. I paid $85 bucks for it. The run down NH sixty something sitting next to it with a knotter missing, brought over $600. Bought a second ford for $130 for parts (it works as well) So a working baler and all necessary parts sitting in the barn for less than $250. Other than usual maintenance and adjustments I haven't had to do anything to them. BTW to date that little baler has produce something like 5000 bales for me (1.7 cents per bale). On recent dealer visits, I looked over the inventory of bailers just to see. NH 268, needs lot's-o work ?parts machine maybe - $1200 MF124, b-e-a-utyfull baler well cared for $1950 NH310, quote "working" but serious problems - $1900 NH315, looks as bad as the 268 but (again) "working" - $3500 JD328, Decent working machine - $6000 Had I been in the market I bought the case in a heart beat.
