Vermeer 504G pickup cam adjustment
Doug the part t
03-13-2005 17:09:45
How can you tell if this adjustment is correct or not correct?
James in NC
03-14-2005 05:01:20
 Re: Vermeer 504G pickup cam adjustment in reply to Doug the part timer, 03-13-2005 17:09:45
You really need to go bale and adjust according to conditions. Depending on what you are baling might change the setting.
Hay Dr
03-13-2005 18:25:22
Unless you have a Super G I do not thing G pickup cam timing was adjustable. The Standard G can be modified to so that the cam track can be adjusted. I'll have to pull the service bulletin on that one to remember. Its only been about 20 years ago but likely William will know without looking it up so if you call CCM ask for Billy Lee Carter.
