V Rake Question
Frank - Illin
03-12-2005 13:43:19
I bought a 10 wheel V rake at an auction. I've never used a V rake before. Question I have, do I rake the field and leave the outside edge for last or the othe way around ? Are there any tricks useing a V rake I should know about ?
Frank
Sid
03-12-2005 21:43:04
 Re: V Rake Question in reply to Frank - Illinois, 03-12-2005 13:43:19
they way we do it is rake the feid first and the head land last as already mentioned. If the baler is not there when we start we start raking the field and when the baler gets there get the headland raked and let the baler get them. I do not know if it is a trick or not but I have found that in thick hay do not let the rake run heavy on the ground ans it will feed through better without balling up.
thurlow
03-12-2005 20:04:19
Well, it all depends; you can do it either way. You raking it all and then baling or is the baler a few minutes....or hours....behind you? If it's a one-man show and you've got to rake it all before baling, I'd recommend raking the field first and the headlands last; that way, you don't tear up your outside windrow(s) when you turn around over them. If the baler is right behind you, I'd say get the outside first. Tricks? Wheel rakes don't rake well in sharp turns.
thurlow
03-12-2005 20:03:14
Well, it all depends; you can do it either way. You raking it all and then baling or is the baler a few minutes....or hours....behind you? If it's a one-man show and you've got to rake it all before baling, I'd recommend raking the field first and the headlands last; that way, you don't tear up your outside windrow(s) when you turn around over them. If the baler is right behind you, I'd say get the outside first. Tricks? Wheel rakes don't rake in sharp turns.
