john deere fertilizer spreader
anderson farms
03-11-2005 03:32:50
Wanted to know the model numbers of the little fertilizer carts made by john deere. I would also like to know of any other brand that made small carts. Thank you for any help
James2
03-13-2005 10:21:13
 Re: john deere fertilizer spreader in reply to anderson farms, 03-11-2005 03:32:50
JD in 1960 did not have a spin spreader. In 1965 they introduced a 1.5 ton model 301 which had a single axle with dual wheels. In 1971 JD had three spin models: a 2 ton model 602, 5 ton model 605 and an 8 ton model 608. The 602 had single axle with larger diameter flotation tires. Both the 605 and 608 had oscillating tandem axles with smaller diameter flotation tires, abet the 608 being larger. In 1962 New Idea offered a 1.5 ton spinner, a model No 111. It was a single axle, with larger diameter tires (corn picker tires/wheels). The NI literature shows there were eight other competitors at this time, ranging from .75 to 2 ton. Specifications are given but not any names.
paul
03-11-2005 16:38:57
You mean a drop fert, looks like a lower grain seeder but drops fert out the bottom? Mine is a Van Brunt / JD model.
--->Paul
Tim(nj)
03-11-2005 14:51:43
I don"t know the numbers of the Deeres, but Allis-Chalmers had a 402F with 4000 lb. capacity. Avco EzFlow/ New Idea also had buggies in the 3-4000 lb. range.
