AC corn planter parts
Ishmael in KY
03-08-2005 19:31:31
We have a 4-row Allis Chalmers no-till corn planter. I think it"s a 600 series. We need some parts before we plant with it this year. My question is, will I have to buy parts from AGCO, or are there aftermarket parts available for AC planters. I think I need the following parts:
1. The no-till coulters have lost their spring. There is a rubber disc in them that looks like it can be replaced.
2. The bearings or bushings are worn out on all the closing wheels.
3. One of the disc openers is broke and several more are loose. Do you replace the whole thing when they start getting loose?
Thanks in advance!
smirkey
03-09-2005 11:25:56
 Re: AC corn planter parts in reply to Ishmael in KY, 03-08-2005 19:31:31
i have a new one of those no til coulter arms with the rubber disc in my shed. let me know if i can help you out.
Brad Webster
03-20-2006 16:02:21
 Re: AC corn planter parts in reply to smirkey, 03-09-2005 11:25:56
Do you still have the AC colter arm. I have a friend looking for some so if you do send price and phone number or address
Thanks
Brad
JMS/MN
03-09-2005 08:53:50
I think the disc coulter arm with the rubber is the same as the coulter arm AC used on some moldboard plows. I don't think it is replaceable- isn't it molded into the two steel parts? I have no idea if that is still an available part- might need to look around junk yards, etc. The loose disc openers have worn bearings. The planter manual should indicate new size diameter and recommended replacement size. If they are not worn too much you can grind of the rivets holding the bearing retainer to the disc, and install a new bearing. If the openers are bolted onto the frame, it is likely that they used left and right hand threads, depending on side.
paul
03-08-2005 22:01:41
Shoup lists some parts for 50, 71-2-3-4-7-8-9, 100, & 385 units. many time parts cross to something else as well. It will help if you have a parts list. Shoup is on-line, but the paper catalog seems better. They are pretty good if you call& talk to them about your needs as well.
Simple bearings I can often get at a local NAPA or other supply place cheaper than at the dealer.
Many disc openers have simple ball bearings in them & can be replaced, but if the blade is worn down - might be better in the long run to repace the whole disk/bearing unit.
--->Paul
