IH/Mcormick Model 70 plow- What size cylinder?????
MN farmer
03-08-2005 11:33:57
What size/stroke"'s hyd cylinder is best for this 3 bttm plow?
Hugh MacKay
03-09-2005 02:11:38
 Re: IH/Mcormick Model 70 plow- What size cylinder? in reply to MN farmer, 03-08-2005 11:33:57
MN farmer: The stroke for an implement cylinder is always 8", but the cylinder must be an implement cylinder as some other cylinders may have the wrong closed length.
On the bore side of this question, a lot depends on the gpm hydraulic output of your tractor. Since bore controls speed of lift, this is quite important in making nice even headlands. The speed you are travelling plus speed of plow lift will control making every furrow the same length. When I farmed I used to keep numerous implement cylinders around, 2.5", 3" and 4" bore. Depending on the job and the tractor would govern which cylinder was used. You will find this a trial and error issue. For the most part 4" will be used on big trailer implements as you don't want that big weight going up or down very fast. Haybines on the other hand you go 2.5" as you want speed. I had 3 and 4 bottom trailer plows and while anyone of the cylinders listed above would lift the plow, I also had tractors with 12 gpm and 17 gpm hydraulic systems. All three would pull the plows but each better with different bore cylinder. My recomendation if your tractor is less than 12 gpm go with 3" bore, if more than 12 gpm go with 4" bore. You don't want that plow coming out of the ground like a jack in the box.
JMS/MN
03-08-2005 14:44:53
Standard stroke for a cylinder for that type of job is 8 inches. Usual diameter is 2 1/2 or 3 inches. Might even get by with a two inch. Plows, field cultivators, discs, run about the same. Also depends on system pressure. It needs to match.
