MYERS 6 FT SNOW BLADE WON'T LIFT, HELP!!!!
Peter(Ottawa)
03-08-2005 09:50:02
I was using my blade( 6foot Myers E45 ) to clear snow on Sunday and it worked great, took it out last night and it lifted a few times then no lift. The blade will tilt side to side no problem, the battery is fully charged. I filled the resevoir( added about 4 oz), bled the line at the right tilt cylinder , added more fluid to replace from the bleeding. The main cylinder did lift once, after bleeding , but did not hold ( down she came). What should I do?????
Thanks, Peter
Michael Soldan
03-08-2005 20:36:32
 Re: MYERS 6 FT SNOW BLADE WON'T LIFT, HELP!!!! in reply to Peter(Ottawa), 03-08-2005 09:50:02
Sounds like you identified the problem...Your main cylinder..could have ice in it or a seal going out and leaking or it still has air in it.Your tilt is working ok so it has to be in the cylinder and not the pump. There is no snow or ice build up that is binding the plow from lifting, no broken brackets .. so follow up on the pump...Mike in Exeter Ontario
RayP(MI)
03-09-2005 16:29:24
 Re: MYERS 6 FT SNOW BLADE WON'T LIFT, HELP!!!! in reply to Michael Soldan, 03-08-2005 20:36:32
Or the relay driven valve that is supposed to close to hold the blade up is leaking - my Monarch will lift OK but slowly drift down, think it's the same problem. Gotta work on that some warm summer day!
RayP(MI)
03-09-2005 16:29:10
