What do you charge to plow,disc, per acre?
Joseph Sakowicz
03-06-2005 05:44:44
I want to plant a couple of food plots this year. Probably five 2 acre plots in central NY. As I understand it I have to plow, disc ,put down Roundup, and plant. What would you guys charge per acre where you live. I have a Ford 650 that I will Brush hog with. The fields are over grown but not to bad. Were planted a couple of years ago with cattle corn. If you want to shoot me an email thats ok too. Thanx
leland
03-06-2005 09:42:34
 Re: What do you charge to plow,disc, per acre? in reply to Joseph Sakowicz, 03-06-2005 05:44:44
You would be better off to disk a fire break around each field then torch it to clean it up this also kills a lot of weed seed then turn it. As for all of your work on a 2 acre plot plowing and disking 100.00 each time and bush hogging 75.00 each time bacause travel time is also a thing to consider also you burn fuel to get there. I do gardens in the spring here and get 40.00 for a 10x20 garden and I am out in 15 minutes or less bacause I charge the same as the rental store and I supply labor to boot.
Gerald J.
03-06-2005 07:30:55
Most state extension services have annually updated bulletins showing typical charges for custom farming operations. I know Iowa http://www.exnet.iastate.edu/ and Missouri http://muextension.missouri.edu/xplor/agguides/agengin/#Farm Machinery do.
Round up doesn't do anything for bare ground. It only kills what living plants it hits. It has no residual either.
Gerald J.
mike brown
03-07-2005 06:53:51
 Re: What do you charge to plow,disc, per acre? in reply to Gerald J., 03-06-2005 07:30:55
I think about $25 dollars and acre plus fuel to plow crop land in CNY. Good luck getting a custom operator to be interested in ten acres. Not enough to show up for. So you will probably have to pay more.
Joseph Sakowicz
03-07-2005 13:15:11
 Re: What do you charge to plow,disc, per acre? in reply to mike brown, 03-07-2005 06:53:51
Does that include the planting of the clover or alfalfa? ( I pay the cost of the seed)? Does it need to be disced or just plowed? Their are some local farmers nearby and I just would like a rough idea before I talk to these guys. Thanx
mike brown
03-08-2005 14:18:25
 Re: What do you charge to plow,disc, per acre? in reply to Joseph Sakowicz, 03-07-2005 13:15:11
That would be just to plow. Fitting and planting anything after plowing is your job or extra.
If you want to establish a seeding, You can have it sprayed with roundup and have it no tilled into the dead sod. Fitting that old sod after plowing will take some time.
