Servis Saturn Mod#Sat5 Rotory Mower Question?
Davy
03-03-2005 15:32:07
I have a Sat5 Servis mower that I am changing blades on, had no problem getting the old blades off (lot of beating) but here"s my question, the stump jumper seems to have some play in it, the output shaft on the gearbox is tight but the stumpjumper and blade mounts wobble, is this normal or is there something worn out and should be looked at? Looks like it is held on by 6 bolts (which are tight) and a large self locking nut in the center (where the whole thing is moving, do i need to tighten the nut or is there a keyway there or what? Looks like it"s been there a 100 years but before I spend the money for new blades and pins ( about $90.00) I need to know if this is something terminal or can i fix it? Thanks
